Help! Think I F'd up! - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 04-10-2017, 08:59 AM Thread Starter
Quoted: 6 Post(s)
Don't know how(nvr ck oil!) Road H/M for 75 miles with a more than normal tic. Long story short, Chris @CMR adjusted my valve. Still load, checked and NO oil! So75 miles no oil. Topped 2 qts and road 120miles. Got home changed oil, black!! Mobile 1 is what i've always used. Engine still knocks. Should i just keep riding because damage is done? is it the timing chain? imma gonna try and post video , thanks
here's a link to youtube of the Engine noise.
https://youtu.be/Y0ZnJqMKYVg
djbleach is offline
post #2 of 7 Old 04-10-2017, 08:12 PM
Quoted: 80 Post(s)
YEP but now you get to +3 the crank, do a big bore ,+1 the intake valves , port and find out how much fun it is to remove and replace the engine
751 ,barker pipe, stage 3 hotcam,+3 stroker,
+3 big bore , +1 intake valves, Hard Welded Rockers,KW springs, port work, clutch mod , air box removed , dynojet commander V w/auto tune , lowered rear end , TRX450R front shocks ,and one more mod I 'm not talking about
cataway is offline
post #3 of 7 Old 04-10-2017, 08:35 PM
Quoted: 149 Post(s)
So when valves were done, No one checked oil level? Hard to say but sounds like noise is down low, so my guess crank bearing or both. Was quad smoking or leaking the oil, it had to go somewhere???
post #4 of 7 Old 04-10-2017, 08:57 PM Thread Starter
Quoted: 6 Post(s)
yeah, after did the valve oil was checked. when he adjusted the valve u could c some oil so it seemed like there was oil. no smoke, not sure where oil went? i hope i remembered tonput it back n when i changed oil.
djbleach is offline
post #5 of 7 Old 04-13-2017, 11:56 AM
Bobinxxi's Avatar
[QUOTE=djbleach;234713not sure where oil went? i hope i remembered to put it back n when i changed oil.[/QUOTE]
Yup. You F'd up.
If you rode that much with no oil, I'd think the motor would have froze up, not just made a tick or knock?
Bottom line, don't continue to drive it with the noise, it can only get worse and do more damage = more$.
Park it now and fix it.
.....After listening to your video, I'd be afraid to even start it. Bottom end is gone.
PRM Desert II bumper and PRM Control Grab bar, Houser anti-vibe Pro-Bounce nerfs, DS450XC shock mod, ROX anti-vibe 2" riser, Tusk billet gas cap, Billet exhaust cap (for the speed)
more to come.....
Bobinxxi is offline
post #6 of 7 Old 04-16-2017, 05:09 PM Thread Starter
Quoted: 6 Post(s)
Took it to a shop and he'll look into it for $75 and let me know how much. Funny when I took it to him the noise wasn't profound. It had to warm up the night before to be herd. I'm wondering if the oil got stuck on the pistons or something causes the Hard compression? I'll keep ya posted. Ebay has a rebuilt for $3k. I'm hoping half that for this guy to rebuild!
djbleach is offline
post #7 of 7 Old 04-18-2017, 01:05 PM
Bobinxxi's Avatar
No way I'd pay $3k for a rebuild. You can find good running stock 700xx for that kind of money. Pull the engine and part the rest out. Or just part your's out and go find another one that runs good.
more to come.....
Bobinxxi is offline
Human Verification
