Ecm blowing fuse - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 04-12-2017, 09:35 AM Thread Starter
Ecm blowing fuse
Hi guys, I'm having a problem with my trx700xx blowing fuse and shorting the ecm.this happen on the trail the first time, so I replaced the fuse for the ecm and replaced the ecm. I then started checking for shorts on wires feeding from ecm to sensor with a meter, an found no shorts. I started it, an it ran for a few minutes, as soon as I hit the throttle a few times, it blow the fuse again , I ohm the power on the ecm and its was shorted again. I'm not sure why there is a over current when I increase the RPM. I check the injector, bank sensor, the ignition primary circuit, coolant sensor, Iacv sensor. Any suggestion ?
panther is offline
post #2 of 3 Old 04-12-2017, 10:52 AM
Quoted: 44 Post(s)
Over current does seem odd, but maybe check the regulator?
mumbauer is offline
post #3 of 3 Old 04-12-2017, 02:48 PM
Quoted: 152 Post(s)
Stator? Not sure but I think someone posted about this issue in the past. I will look for a bit, had no luck at first sorry. Was quad recently in any deep water?
Human Verification
