decompression question - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-12-2017, 06:53 PM Thread Starter
just got xx cheap as it is was making a bad top end noise. valves are in spec but the decompression lobe is very sloppyand seems loose does anyone have a good cam and see if thats a tight fit? im assuming it should be but this one is very very loose on cam,hoping thats the noise,thanks., Big b
elm327 is offline
post #2 of 6 Old 04-12-2017, 07:59 PM
Quoted: 81 Post(s)
its loose ,but it works ?
751 ,barker pipe, stage 3 hotcam,+3 stroker,
+3 big bore , +1 intake valves, Hard Welded Rockers,KW springs, port work, clutch mod , air box removed , dynojet commander V w/auto tune , lowered rear end , TRX450R front shocks ,and one more mod I 'm not talking about
cataway is offline
post #3 of 6 Old 04-13-2017, 09:27 AM Thread Starter
i tried to post a video but it wont let me. search youtube 700xx decompression issue
elm327 is offline
post #4 of 6 Old 04-13-2017, 07:44 PM
Quoted: 81 Post(s)
looks normal to me
cataway is offline
post #5 of 6 Old 04-13-2017, 07:49 PM
Quoted: 81 Post(s)
but if you want to buy a new cam .have at it . you cant buy just the dacomp part
cataway is offline
post #6 of 6 Old 04-13-2017, 07:50 PM
Quoted: 81 Post(s)
tell us about the cam chain . is it tight ?
cataway is offline
Human Verification
