High idle after running hot - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 05-12-2017, 01:27 PM Thread Starter
Don't have a manual and looking for a solution. Runs fine, no engine codes. No problems on startup. Once it's up to operating temperature it seems to idle around half throttle. Back to normal after sitting for couple hours.
Jason Stapel is offline
post #2 of 6 Old 05-12-2017, 09:19 PM
Quoted: 81 Post(s)
can you force it down at the throttle body ?
751 ,barker pipe, stage 3 hotcam,+3 stroker,
+3 big bore , +1 intake valves, Hard Welded Rockers,KW springs, port work, clutch mod , air box removed , dynojet commander V w/auto tune , lowered rear end , TRX450R front shocks ,and one more mod I 'm not talking about
cataway is offline
post #3 of 6 Old 05-13-2017, 12:39 PM
Quoted: 151 Post(s)
Should be a active link for the pdf manual here. If you can't locate it let me know and I will add link in this thread.
post #4 of 6 Old 05-13-2017, 09:06 PM Thread Starter
Got the manual, have to dig into it this weekend.
post #5 of 6 Old 05-23-2017, 12:21 AM Thread Starter
Update, problem seems to be fixed after tightening the hose clamps on the throttle body. Best guess, the rubber would get warm and expand enough to let in extra air through the seal affecting the sensor for the fuel/air mixture.
post #6 of 6 Old 05-23-2017, 08:07 AM
Quoted: 151 Post(s)
Great, I'm glad you got it figured out.
Human Verification
