Easiest way to replace CV boots - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By cataway
post #1 of 9 Old 05-16-2017, 12:54 PM Thread Starter
Hey guys, so my right CV boot got a tear in it about a month ago and about a couple weeks ago I've noticed it making a clicking type noise when I'm going slow so I'm sure all the grease leaked out of the opening and so I wanna know the easiest way of replacing the boots on both sides without taking out the axles themselves. Hopefully the bearing didn't go bad, thanks.
Kubi07 is offline
post #2 of 9 Old 05-16-2017, 06:13 PM
Quoted: 81 Post(s)
the easiest way is to have some one do it for you
M_Quick likes this.
751 ,barker pipe, stage 3 hotcam,+3 stroker,
+3 big bore , +1 intake valves, Hard Welded Rockers,KW springs, port work, clutch mod , air box removed , dynojet commander V w/auto tune , lowered rear end , TRX450R front shocks ,and one more mod I 'm not talking about
cataway is offline
post #3 of 9 Old 05-16-2017, 08:55 PM
blakjak619's Avatar
Quoted: 33 Post(s)
Lol 2x on having someone else do it... It's a huge pain in the butt that's for sure if you search the forum you'll see all the misery we've experienced trying to get the right side to pop out. Good luck lol
blakjak619 is offline
post #4 of 9 Old 05-16-2017, 09:17 PM Thread Starter
Ugh well damn, I was really hoping I could just take out the knuckles and put in the new boots. Well that's disappointing. Thanks for the reply guys.
Kubi07 is offline
post #5 of 9 Old 05-17-2017, 06:01 PM
Quoted: 81 Post(s)
you can but you asked for the easiest way to do it. if you have one that's clicking it may well should be replaced
cataway is offline
post #6 of 9 Old 05-18-2017, 09:06 AM Thread Starter
I'm gonna have to open it up and take a good look at it this weekend. Also, is there something you guys use to clean out the grease? Or do you just wipe it off.
Kubi07 is offline
post #7 of 9 Old 05-18-2017, 06:15 PM
Quoted: 81 Post(s)
paper towel ........lots of paper towel
cataway is offline
post #8 of 9 Old 05-18-2017, 06:22 PM Thread Starter
Gotcha, I'll update you guys this weekend if everything goes well. Thanks again.
Kubi07 is offline
post #9 of 9 Old Today, 03:59 PM Thread Starter
Okay, so I finally started working on it and I got stuck where everybody else got stuck. That right side inboard joint just doesn't budge. I've used pry bars and still nothing. Any help would be appreciated, thanks guys.
Kubi07 is offline
Human Verification
