Kinda Barclaws for Stock rims- Go up in size? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 02-09-2017, 08:32 PM Thread Starter
Quoted: 5 Post(s)
I was wondering if anyone is running Kenda Bear claws and what sizes did they go up to on the stock wheels?
I am trying to find a place......
Kyle Lukas is offline
post #2 of 11 Old 02-09-2017, 08:42 PM Thread Starter
Quoted: 5 Post(s)
Can I run these sizes without rub??
23/7-10
24/10-11
Kinda makes the bear claw in this size...........
post #3 of 11 Old 02-09-2017, 09:00 PM
Quoted: 4 Post(s)
23 will rub some nerfs at full lock, not sure about the 24 for the rear
Sent from my iPhone using Tapatalk
Dayton lock is offline
post #4 of 11 Old 02-10-2017, 01:16 PM
Quoted: 149 Post(s)
24's may be okay. I have some 25's that only rub the heal guards a little durring fast slidding turns and when landing after jumps.
post #5 of 11 Old 02-11-2017, 01:05 AM Thread Starter
Quoted: 5 Post(s)
I ordered them and will have them on next week so I will let u know and take photos
post #6 of 11 Old 02-11-2017, 10:41 AM
Quoted: 149 Post(s)
They are a big heavy tire. Not your typical sport quad tire for sure.
post #7 of 11 Old 02-11-2017, 12:15 PM Thread Starter
Quoted: 5 Post(s)
I do trail riding and mudding. I went with a 13T for the front also.
post #8 of 11 Old 02-14-2017, 04:18 PM
my current setup is 24x9-11 , those tires are very grippy when cornering , you cant ride the 700xx like the stock sport tires . had them for 5-6 years now , im glad to get rid of them , and will get kenda kutter ,
the reasons I bought the bearclaw were , some more grip ( but was too much ) the price , the clearance . , if you really want bearclaw i suggest you 23x8-11
gm700 is online now
post #9 of 11 Old 02-22-2017, 10:35 PM Thread Starter
Quoted: 5 Post(s)
The setup with the tires.........
post #10 of 11 Old 02-23-2017, 03:35 PM
Quoted: 80 Post(s)
looking over inflated ??
751 ,barker pipe, stage 3 hotcam,+3 stroker,
+3 big bore , +1 intake valves, Hard Welded Rockers,KW springs, port work, clutch mod , air box removed , dynojet commander V w/auto tune , lowered rear end , TRX450R front shocks ,and one more mod I 'm not talking about
cataway is offline
Human Verification
