Chain Adjustment? - Club700XX - Honda TRX700XX Forum
Go Back   Club700XX - Honda TRX700XX Forum > TRX700XX Technical Forums > Motor, Transmission, Electrical, Intake & Exhaust
Thread Tools Search this Thread Display Modes
Old 01-02-2010, 12:49 PM   #1
EAHILLEN
Junior Member
Default Chain Adjustment?
can someone write up a step by step chain adjustment guide, i dont have the manual and searching here and google hasnt turned anything up.
EAHILLEN is offline   Reply With Quote
Old 01-02-2010, 03:33 PM   #2
Brokenbones
Brokenbones's Avatar
Default
loosen the big bolt that look like a dirt bike wheel one and on each side there are cams with numbers 10 15 20 25 push on those until you get 3/4inch loose up and down. That take about 5 min.
__________________
Built, reliable and hard trailriden!
Brokenbones is offline   Reply With Quote
Old 01-02-2010, 07:43 PM   #3
Nasty700xx
Nasty700xx's Avatar
Default
If you have a new chain put it on snug and run hard a couple of minutes and check it. It usually will stretch and be perfect for you. It takes a 24mm socket or wrench to loosen or tighten the rear adjustment bolt.
__________________
Nasty 700xx
Barker performance exhaust
EHS racing fuel programmer
EHS racing air box lid
ITP holeshot XCT tire front and rear
Hiper beadlocks
Houser long travel A-Arms and steering stem
Elka long travel elite shocks (front)
Elka remote resevoir rear shocks
Pro taper fat bars
IMS fuel tank
DG full skids
Precision steering dampner
Hinson Clutch
Moose dual gasser throttle
DG fat nerf bars
DG fat pro V front bumper
Powermadd hand guards
ASV C5 brake/clutch levers
Nasty700xx is offline   Reply With Quote
Old 01-02-2010, 07:52 PM   #4
Baxter
Default
I run my chain a little tighter than the manual say's to stop the clatter when braking heavy on the rear.
__________________
Ed at http://www.teixeiratech.com/
Alex at http://www.proarmor.com/
Jim at http://www.motowoz.com/
Eric at http://www.ehsracing.com/
Kyle at www.l8tonracing.com
Baxter is offline   Reply With Quote
Old 01-02-2010, 09:09 PM   #5
Simplyorange
Simplyorange's Avatar
Default
move it to the adjustment as tight as you can with your hand on the cantelever, then go back 1 notch and itll be 3/4" of play.if i would have seen this thread earlier i would have done a write up for you because i did my 13t about 3 hours ago.
__________________
2008 TRX 700XX (Black/Charcoal)
13T,Stage 1 hotcam,11:1 CP piston,L8ton Sway bar,Orange Maier Plastics,21" razr 1 front,ITP Sandstars on 10" ITP T9 Pro Series,FMF powerbomb/powercore.EHS programmer next.
2007 GSXR 1000 (Orange/Black)
-1,+2 Driven Kit,K&N, Full Leovince stainless exhaust,PcIIIUSB/Dyno tune,Hyperpro Damper,ASV Levers,Woodcraft Engine covers,Woodcraft Clipons,Xenon HID,Carrozzeria Wheels,Galfer Rotors(gsxr.com 2010 bike of the year)
Simplyorange is offline   Reply With Quote
Old 04-30-2010, 12:20 AM   #6
dmorris
dmorris's Avatar
Default
do u need to take out the pins before u tightin it up
dmorris is offline   Reply With Quote
Old 04-30-2010, 07:22 AM   #7
Tory trx
Tory trx's Avatar
Default
What pins are you talking about? You just loosen the big bolt and nut(like a dirt bike) and move the adjusters. Its that simple. I did not remove anything. Just make sure that the adjusters are set to the same degree.
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist"
Tory trx is offline   Reply With Quote
Old 04-30-2010, 08:07 AM   #8
crwh45
crwh45's Avatar
Send a message via AIM to crwh45
Default
When you move the cambers tho, make sure they match up, as in both are 15 and 15, or 20 and 20. There are no pins, unless you are talking about the pins that the cams go around (the pins that indicate what position you are in) and they stay there. You may need a rubber mallet to move the cams.
__________________
2008 700xx; Power Bomb header with power core 4 exhaust, Power Programmer III, pro armor nerfs, prm products control front and rear bumpers and full skid, 10" ITP rears, ITP Baja's fronts, RZR 2's all the way around, Uni filter, 13t sprocket, CCP steering Damper, DS450 shock swap, Dual Gasser Throttle, bar risers and Moose barkBusters. 730XX kit plus other engine mods!
crwh45 is offline   Reply With Quote
Old 05-04-2010, 12:06 PM   #9
dmorris
dmorris's Avatar
Default
does it have to be dead on the degree i cant seem to get them exactly the same
Old 05-04-2010, 02:42 PM   #10
crwh45
crwh45's Avatar
Default
Yes, you want the same on both sides. If you cant get one as high as the other, back off on the other one 1 degree. If you have them different, then your rear sprocket will not be lined up completly with the front sprocket. Just tap it w/ a rubber mallet if needed, and make sure the ass end is off the ground.
__________________
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
