2nd this.Hi Lomo, man be carfull with offsets my mate has ITP 10inch with 1 inch offset and the drive shaft boots just hang in the breeze waiting to be torn to bits, why dont you stay with your 11inch.
Overlord
You have to remember that with 10" rear wheels you have a larger choice of tires but they are ALL wider than the stockies. This means that not only will you be increasing width with the wheels but with the tires also.Drew,
I'm getting ready to get some 10" wheels for the back, w/RAZr 2's. ITP has the T-9 Pro series 10X7 rim, which has a 4+3 offset (4" inside X 3" outside), I believe this is the same offset the stock rims have. You must remove the mud scrapers if you go to a 10" wheel, but this will open-up the tire selection for you.
aggghhh so even with wider offset fronts and extended front arms the front will still be narrower?You have to remember that with 10" rear wheels you have a larger choice of tires but they are ALL wider than the stockies. This means that not only will you be increasing width with the wheels but with the tires also.
ITP 10" wheels are about +1" over the stock 11" wheels. The MAXXIS rear tires are +2" over the stock tires.
With setup you will be at or over 50" wide without spacers.
