Alright, I am wondering what will need to be done to put 12" ss wheels on my XX. The rear seems easy enough just putting some 4x110 pattern hubs on from a 450r,400ex, or 300ex. Then what offset wheel would I need to stay close to stock width? I should also be able to use some other hubs for diff patterns. I know the kfx 4x137 pattern hub works also. Also a Mojave hub with a 4x156 pattern.
Fronts I would need some adapters but I don't want to add much if any width. Is there a possible way to get an offset and spacer combo to where it's not much if any wider?
