M_Quick,
The sound of that yellow Mustang is beyond fantastic. Will watch this more then once. Lol
WOW!!
Thanks,
Sid
Thanks Sid!
Which yellow Mustang, lol. I enhanced well turn up the sound on the 2012 GT that took off from the rest area, and then the other is a 06GT taking of from 1st side road. The 2012 has the Roush axle back system, not sure what the 06 has. It may not sound better in the video, but trust me it does in person. The 2014 Roush stage 3 is a nice built car, and that 2011 SVT is just crazy the money those guy's have to toss in there street rides. Here's a link to the SVT build if you want some good reading, but w/out being a member pictures are just thumbnails.
http://www.buckeyestangs.com/vb/showthread.php?35856-2011-GT500-Build
And here's what that guy through at a 2014 RS3.
2014 RS3 AluminatorFore Innovations stage 4 return style fuel system ( Rated for 1200 rear wheel horsepower )Upgraded -8 black anodized billet fuel rails
Billet fuel Triple top hat -8 feed and -8 return Fuel rails ran in parallel with regulator after the rails 30 feet of Starlite hose F4i fuel pressure regulator F10 inline fuel filter F3 staged fuel controller. running 1 pump all the time and kick on the second and third pumps only under boost
Reusable stainless steel 10 micron filter Billet fuel filter mounting bracket
Walbro 465lph e85 fuel pumps ( 3 of these puppies )These are e85 compatible pumps
Injector Dynamics ID1000 fuel injector set These are e85 compatible Complete dynamically flow matched set
3.31 ring and pinion
Eaton Tru - Track differential
Oil catch can
Metco LCA's
JLT Bigmouth CAI
Billet oil pump gears
76 mm pulley
McLeod RXT Clutch
MGW Shifter
DSS Drive shaft / loop
15" Race Star wheels - took forever to get!
15" MT Streets
BMR sway bar relocation brackets
C & R Dual pass heat exchanger
Retune on the dyno for e85 and a 93 octane tune
