1 - 3 of 3 Posts
I'm rebuilding the engine for my stepson who ran it low on oil. Basically replacing everything. The decompressor mechanism on the cam broke into pieces and was laying in the crankcase. I can't find one anywhere and he is wanting to go back with a Hot Cams stage 2 which is what was in it. Do I have to buy the entire stock cam just to get the decompressor mechanism?
Unfortunately yes sir you do. Also while your there inspect your rocker arms for wear and tear. . I've heard of alot of issues with bigger cams on these bikes rocker arms not getting along, most likely do to lack of lubricant.
Good luck to you sir
On partzilla and similar, decompressor came toghether with cam, however the service manual explain how to disinstall it from cam, so I would ask to an official Honda if possible buy only it
1 - 3 of 3 Posts
