The problem with a 10" rear rim is that they have to have a different offset to clear the upper a-arm. Makes the back end wider. This will increase the front end push. A 22" front tire will help a bit... 23" will help more, but not enough. IMO. You might try a 11" rim by OMF so that you can keep the same offset... and go to 22-23 on the front tires.My choice is done, execpt the size. it's razr1
Wich one is the best to choice? 11in with stock ugly wheel or 10in with itp nice looking wheel but only 7in wide with 11in wide tire?
ha nice, thank, I don't think to buy OMF wheel this years, so probabely keep my stock rim for this summerThe problem with a 10" rear rim is that they have to have a different offset to clear the upper a-arm. Makes the back end wider. This will increase the front end push. A 22" front tire will help a bit... 23" will help more, but not enough. IMO. You might try a 11" rim by OMF so that you can keep the same offset... and go to 22-23 on the front tires.
front 194.80 a peicedoes any one no what a set of omf cost front only and rear only
