1 - 8 of 8 Posts
i have a fmf q4 screen in, 13 sprocket, uni filter, fmf programmer, and razr2 22 front ,razr rear22, its been real cold and alot of snow and water. heres the problem when im on it hard in 3 or 4 gear it flames out kinda like its flooded, it just dies, at not a good time i may add. it never done that till the programmer was installed, i had the opposite it would die on the low end . so where do i start?
Hows the connections on the programmer? could be a issue in the injector wire or RPM wire.
if not might be too much fuel at top end RPM.
Are you still running the stock lid??
im going over all the connections first then im thinking like you it might be getting to much fuel, but it doesnt bog it just shuts down
Pull the plug right after it happens to see what it looks like.:hey:
warlock ill try that the next time i get in the woods, i never had that problem till i put on the programmer im thinking its dumping to much fuel and flooding it out
You may also want to check the stock map of your FMF to make sure it has not changed. You could also disconnect the FMF and try it again.:hey:
1 - 8 of 8 Posts
