ok guy let me know if this ever happens to you. when i'm riding my 700xx sometimes it feels like it has a flat tire. but when i stop and check all the tires are fine and are aired up. so what make the 700xx feel this way sometimes.
6 psi is all you are supposed to run in rear. If you run 10 psi it will ride really rough so maybe that was your problem. Try running 6 psi in both rear tiresI found that my left rear tire only had like 6 psi of air in it so I aired it up ti 10 pis like the other on and it seems to be fine again. I will look at my control arm bushings though.
thanks for the help.
Easy diagnosis.dirt roads are crowned and get washboard. mine feels the same way. on pavement or grass it feeels fine. just go faster, if something falls off then you know what needs to be fixed
