is his banshee stock or modded? cause i think most other quads have a hard time even with a stock banshee... u start racin against modded banshees... it could be a lost cause for any quad.So i have no choice, I need the big 3 . Hope to beat him next time. thank's
Forget the drag racing. Take him down a trail with you, then go back and help him collect the parts that are left of his Banshee!So i have no choice, I need the big 3 . Hope to beat him next time. thank's
To answer this question. The XX has about 52.9 hp and the raptor is around 46 hp. So, XX has more power. Of course, the rappy is lighter in weight, but when it comes down to it power to weight ratio is about the same, so it makes them pretty equal stock.IS the xx less powerfll???![]()
Not to question you but where is the dynosheet comparing both stock? I'd really like to see this (same dyno same day both stock). That would be a great comparison.
Yup scuzz, havent seen one yet, would like to see ir for educational purposes (LOL)
The numbers above posted by Scuzz is crank HP. The dyno chart gives rear wheel hp (rwhp). Stock = 42.whatever hp at the rear wheels and the other curve I'm guessing is the porting, throttle body, and cam only, not the big 3, so this means there is about a 13 hp gain.http://www.club700xx.com/vb/showthread.php?t=658
So only 3 hp gained with porting, throttle body and cam? a lot of money for 3 hp, hopefully with this done and big 3 (full exhaust) this will be a lot more?
