Bad option
Bro, thats a bad option first up ya cv boots are just siting out in the breeze waiting to be torn to peaces (thats why Honda run the 11inch wheel to protect them).
Most of the time wider in the rear is not always better, at that width your almost wider than what your wheel base is (so it would be a bitch to turn).
Most of the time you want your front to be slightley wider than your rear not the other way around.
The max you can go in front width on the XX is around 1.5 inches a side, if you go more your quad ends up wider than your wheelbase, which is no good for handling and cornering.
If ya can put the 11inch back on and save for a front end from Ed.
