Any Ideas. That the limit where I ride.:confused:
L Loneranger · Registered Joined Oct 18, 2009 · 22 Posts Discussion Starter · #1 · Oct 18, 2009 Only show this user Any Ideas. That the limit where I ride.
smo0oth1 · Premium Member Joined Nov 14, 2008 · 2,932 Posts #2 · Oct 18, 2009 Only show this user Fmf Q4
L Loneranger · Registered Joined Oct 18, 2009 · 22 Posts Discussion Starter · #3 · Oct 18, 2009 Only show this user Do I need a programmer if I run a aftermarket exhaust ?
bkelley · Registered Joined May 2, 2009 · 253 Posts #4 · Oct 18, 2009 (Edited) Only show this user The HMF Quiet Race Series should be right in that range. Edit: Actually, looks like it's in the 96db range.
smo0oth1 · Premium Member Joined Nov 14, 2008 · 2,932 Posts #5 · Oct 18, 2009 Only show this user With a full exhaust you absolutely need a programmer. With just a slip-on you can get by without it.
bkelley · Registered Joined May 2, 2009 · 253 Posts #6 · Oct 18, 2009 Only show this user It's highly recommended.
smo0oth1 · Premium Member Joined Nov 14, 2008 · 2,932 Posts #7 · Oct 18, 2009 Only show this user It's highly "debated"
L Loneranger · Registered Joined Oct 18, 2009 · 22 Posts Discussion Starter · #8 · Oct 18, 2009 Only show this user HMF is too loud at 96db. there really strict being a private ride. Thanks smoOoth1.
OzLinc · Registered Joined Aug 7, 2008 · 445 Posts #9 · Oct 18, 2009 Only show this user Tip......check how its measured as 94db is 96db on a Type-2 db meter. Type-2 is what is usually used.
5W0P3 · Registered Joined Dec 2, 2008 · 2,171 Posts #10 · Oct 19, 2009 Only show this user Move to Texas!
