Looks great man! How are you liking the ProArmor bumper and nerfs? Any install problems with the nerfs? Did everything line up? Any problems with the welds on the bumper?
TBird is exactly right! I tried to find someone locally that can make custom cables, or that would be able to put a barrel on the end of the cable I already had. I found nothing, so I went back to the same bicycle store where I got the tandem bicycle brake cable and outer casing, and I got the special bolt with a hole through it. Then I just trimmed up the lever down on the tranny for the bolt.what is the last photo showing ?
The bar mounted reverse works awesome, but finding the right piece to do it was a PIA!!! Works Connection lists the part in all their catalouges and online pages, but they dont actually make it anymore, they do have a replacement that they send out, which the lever is on the front of the clamp and you have to push the button down instead of forward, it didn't work because it interfered with the throttle cable.I like the bar mounted reverse . Gunna try that and you have the EHS programmer in the same place as me but I didn't need to cut the airbox to do it .
The 700xx looks sweeeetttt !
Good job my man . :yay:
