I got tired of getting mud sprayed up in my face. So I fixed it. I added the front fenders off a Cam-Am DS650. After a lot of head scratching. I was able to fabricate some mounting brackets to the front knuckles so the fenders would turn with the tires. The brackets mount between the upper and lower ball joints then over to the tie rod end. It also has a mounting tab so you can bolt the fender on and off. I cut off the old mounting point from the DS fender and added a flat mounting plate to it.
Hope is might give you guys some ideas to keep the mud out of your eyes.
I've had them for over a year now and there are still working great.:xx:
Here are some photos
http://s476.photobucket.com/albums/rr125/duravette/TRX700XX/TRX700XX Front Fenders/
