1 - 2 of 2 Posts
2008 trx 700 didnt start due to a electrical short on fuel pump wires, once resolved the bike starts up well but must be idling at 5000 rpm (total guess) but cant seem to control it. no air leaks...
I cleaned the iacv sensor with some carb cleaner... still idles high
When i unplug the iacv sensor completely while it idles high and has no change
You think its the iacv sensor?
If the sensor wasn’t ruined before you sprayed it with carb cleaner it is now. It’s carb cleaner, 700xx doesn’t have a carb! They make products for intakes, mass airflow sensors ect. Use them. Plus if it wasn’t dry even cleaned properly it can short out.
1 - 2 of 2 Posts
