1 - 4 of 4 Posts
How much more air do I put in my tires when running studs?
Normal pressure is 4-6 lbs.
When I was getting my tires mounted a guy came in with 1 inch spike studs bolted to his tire. He had 10 lbs of air pressure and spun the rim when he went to take off. The dealer ship said to run 20-30 lbs of air in the tires.
The guy was running a tube only inside the tire on a stock rims. He says it goes on a 3 wheel dragster. I think he should of had bead locks with this kind of setup.
I looked every where in the forum and was unable to find any info on air pressure for studs.
I am only running 1/2 in screws on the stock tire and rim. Recreational use only. Should I take my tires up to 20 lbs. so I don't spin the rim?
One of our local clubs just had a "Radar Run" on the lake near me. I studded up my stock tires, 1/2" Kold Kutters, for the runs. They swept the ice so it was glare. I only ran about 3.5lbs in each of the rear tires, no rim spin what so ever. I did not want to run a high pressure because I figured the tire would balloon out and only run down the middle treads. [email protected]
Anyone have pics of there studded tires?
1 - 4 of 4 Posts
