just got 22 10 11 razrs what air pressure u guys running tobe able to make this thing slide also pressure for stock fronts
Doesnt the manual say 6 rear and 5 front?actually, you should run the rears at least at 7... they are more prone to leak around the bead at low pressure, or our normal 4 or 5 in the rear.. it's just the way the wheel is...
That's exactly right!!!..May go even more in the back, figure less sidewall due to the 11" wheel, weaker rims compared to what I run on the 450R, and more weight. Going to have to do some testing to see what works.
