pbi has Much better life then the Renthal aluminum ones but for us they dont handle the power and only last about a weekend
in that case i will need some lessons from you soon my sprockets and chain is about wore out, they lasted2 years the stockers not bad i dont know how many miles is on them but its about 300hrs on my hour meter :xx:Changing the rear sprocket only takes 5 mins including beer.![]()
Thats a great reason to give em a try!!A PBI 39t ali sprocket cost about £40 including shipping, getting a steel 39t sprocket made will be about £150+. So if a use a couple during the year it would still work out cheaper. Changing the rear sprocket only takes 5 mins including beer.![]()
I can buy 4 or 5 ali ones compared to getting a steel one made and with the xx not having a swingarm it does stretch the chain as much as the same chain on the 450r.I have checked from leftover chains from the 700 and 450. So not to worried about putting a new sprocket on a used chain. I changed sprockets all the time and they only have to last 1 season.chain and sprockets should be changed together as just changing the chain or sprocket will lead to premature wear.
I once used an ally rear sprocket and it wore pretty fast..
so then do you replace it with a steel one which will then have a partly worn chain on it, or replace the whole lot again?
Personally i would never use an aluminium sprocket again.
I'll sort some pics out tonite after work.Baxter- I have avoided changing the rear sprocket on my xx because it looks like it would be a pain in the rear. It looks like you would have to take the A-arms loose to get it off. Am I missing something? How about posting some pics. of how to change it out? Thanks
