1 - 3 of 3 Posts
Alpinestars Tech 3 Boots Like New $99 + Shipping Size 10
I only wore them one for about one hour!
My loss is your gain!
• Contoured shin plate is injected with high modulus PU for a high level of impact and abrasion resistance
• Reinforced leather plate runs along rear of the boot
• Extended inside and outside plate guards the side and toe-box area of the boot
• Calf plate designed for maximum grip, support and side contact
• Patented "ankle brace" with shock absorbing ankle padding
• Internal plastic reinforcement on the inner side of the boot is covered by thick stamped suede for increased grip and heat resistance
• Instep flex-zone stitched for maximum support
• Action leather upper
• Alpinestars exclusive high-grip rubber double density compound outsole with a contoured tempered steel shank over injected inside the assembly insole
• Four buckles with memory featuring a quick release/locking system
• High impact resistant buckles made from injected techno-polymer
• Top of the boot is sealed with a Velcro strap connected to elastic stretch PVC
• Poly fabric lining coupled with multi-density EVA
• Removable anatomic foot bed
• Extended gaiter helps prevent water entry
I would buy this but i ware a size 11 shoe!!!
1 - 3 of 3 Posts
