im wondering if anybody had tensioner problems yet, im starting to think more and more that my tensioner is bad.i used a stethascope last night and it seems the tap is concentrated on the right side around the timing chain, it doesnt go away or change at all with clutch use and it a very constant tap.and i cant hear it in the bottom end at all or around the valves. so i have it narrowed down to clutchbasket or timing tensioner.
im going to pull both tonight and inspect, if the clutch basket doesnt have any more play then last time i checked it, then im gong to order a tensioner.but the clutch did have some odd side to side movement last time so i want to check that first..i cant believe im the only one with irregular engine noise, just my luck.
