Is there any difference between ATV trannies and sportbike trannies? I used to clutchless upshift all of the time on my bikes and never had an issue. Haven't even thought about it on the XX, though I wish that I could reverse the shift pattern.I think he is refering to being able to shift it without a clutch, Ive heard that statement before many times. I never recommend shifting without a clutch especially under power. Ive had a buddy that shifted his warrior without using the clutch, he only used the clutch for starting a stopping.
I never did it when riding casually, but on the track I'd just put a little pressure on the shifter, roll off of the throttle, and it would practically shift itself. You couldn't ask for anything smoother. I did a pile of trackdays and never had a hiccup from the trannie. I really don't see where I would need to do it on the quad though, the clutch is more of a tool in the dirt than on pavement.Probably simular, the clutch is there to take the shock out of the synchros.
I never used the clutch to break the rear loose on the track, the throttle did well enough at thatUm...if anything you would use the clutch *more* on pavement rather than dirt. Dirt would give a lot more between gears and allow the syncros to....uh...syncronize.
Taking off you would need the clutch on both.
I held off all day. The thing that I see is wrong is its a black/grey one:lmao::lmao::lmao:
