Yes this normal because you are putting a 11" wide tyre on a 7" wide rim.I just bought 23/7/10 razr and 22/11/10 for the rear on itp pro series and the fronts are fine, but the rear are skinny and tall??? is this normal.? im ordering 20/11/10 and selling these . They are brand new just not my taste.hno:
Huh? any time i ran a 20/11/10 never had issue. Is there a different size 10" rim for back i can order then?:nuts:Yes this normal because you are putting a 11" wide tyre on a 7" wide rim.
i willYou got a pic of them?
Where's the pic that EEHonda asked for? I have no idea what you mean, skinny and tall? Seems to me it is just a looks thing. What you think is skinny and tall may be normal to someone else. The only difference between a 22x11x10 and 20x11x10 tire is the one is 2" larger in diamter. They both should be close to the same width. I don't really know what type of "input" you are expecting.63 views and no input??? All the razr users??? EPIC FAIL:tdown:
When you put an 11" wide tyre on a 7" wide rim the tyre width is decreased to about 91/2" and because it is narrower it causes the tyre to balloon and increases overall diameter.Where's the pic that EEHonda asked for? I have no idea what you mean, skinny and tall? Seems to me it is just a looks thing. What you think is skinny and tall may be normal to someone else. The only difference between a 22x11x10 and 20x11x10 tire is the one is 2" larger in diamter. They both should be close to the same width. I don't really know what type of "input" you are expecting.
There are lots of people like you that have questions. So they look through the threads. Hence you get views. But no info. Not epic fail.63 views and no input??? All the razr users??? EPIC FAIL:tdown:
Yes it does thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! now when you order a 10" rim can you specify the different width? actually they dont look as narrow here as they came with 17# air in them and i lowered to 7 #There are lots of people like you that have questions. So they look through the threads. Hence you get views. But no info. Not epic fail.
I am not sure I understand your question.
I think what your asking is why is the tire tall and narrow. Like Baxter stated the ITP 10 wheel is only 7" wide. When you mount a 11" tire on that wheel it will tend to look narrower than say if you mount it on say a 9" wide rim. The tread width is the same but the section width (section width is the widest part of the tire) is wider on the wider wheel. When a wider tire is mounted on a narrow wheel the tread tends to want to crown out, which gives the tire a more narrow appearance. The only way that I know of to get a wider wheel on the back of this machine is to move the offset out which changes the load on the suspension, wheel bearings and handling characteristic's. Which is a whole other topic. See thread>http://www.club700xx.com/vb/showthread.php?t=4177
I hope this helps.
As far as I know the only one I know for sure available for the XX is the 10X7 size. I thought I read somewhere that a 10X8 is available. I bet Baxter would know.Yes it does thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! now when you order a 10" rim can you specify the different width?
The ITP only comes with a 4:3 offset and DWT comes with 4:4 offset.Yes it does thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! now when you order a 10" rim can you specify the different width? actually they dont look as narrow here as they came with 17# air in them and i lowered to 7 #
Thanks brother!!!! Hoorah....The tires look correct...just run the 7 ish pound of air in them... sometimes its just one of those things we get in our head...like the noises in my engine that are normal that i am bound and determine to make abnormal...all in my head
