do all the controls fit on them? (lights, brake/clutch mounts)Yea just means they're fatter (1 1/8").
What benefit is that? (sorry for all the questions)Yes, the only part that is fatter is the bottom part that attaches to the clamp.
depends on what bars you are talking about and what lights ..the reverse, neural, temp, and lights light console does not fit on 1 1/8 bars. you either must do away with the indication lights ..mount them on one of the plastic panels ... or modify the clip fittings on the console. I myself purchased a trail tech clamp set (only because it had fittings for the indication lights) and it added about 2 inches to the steering stem length... both are good since im 6'6 with long arms.do all the controls fit on them? (lights, brake/clutch mounts)
