1 - 4 of 4 Posts
hola que tal? tengo un problema con el aceite en el honda trx 700, estoy usando un sintetico con aditivos , es un motul 15w 50, cuando uso el cuatri y le hago alrededor de 5 tanques tengo que agregarle casi un litro de aceite, ya le vengo agregando casi 2 litros, y cuando ando no larga humo de aceite por el escape ni lo larga por el filtro, a que se debe esto?, puede ser que el aceite no sea el adecuado? o algun problema de motor?, muchas gracias !!: Gracias:
English?
Kechu,
I think you should switch to a standard Honda oil product such as 10W 30 of 20W 40. Make sure you do not overfill the engine. Two Quarts is enough. Any synthetic additive could ruin your clutch. The oil smoke you mentioned could be from overfilling the engine with oil. Are you seening any oil in the air filter housing?
Where are you located? I tried to get the correct translation but do not know what language you are speaking. Need your help.
Sid
1 - 4 of 4 Posts
