1 - 4 of 4 Posts
2008 trx 700
I just put a new battery in my four wheeler and it won’t hold a charge. How do I tell if my stator is going bad? I think it might be this bc when my four wheeler gets really hot it will shut off at times at random
2007 TRX450ER
Get a volt meter. The battery should show ~ 12.5 volts or a little more. Start the atv and recheck the battery voltage with the engine running. It should show about 14.4 volts.
2008 trx 700
I tested it and I’m at 12.8 volts with it off and when I start the four wheeler it stays at 12.8
Doesn't appear to be charging. Unplug the stator connector and check for continuity between each of the 3 wires, it should be around 0.1 ohm. Then check for continuity between each wire and ground, there should be none.
1 - 4 of 4 Posts
