How do i get rid of front push so i can turn better in the sand?
I would think the best thing to do if you want to stay stock width is get the Teixeira Tech upper replacement a-arm. That way you can adjust the castor and get the 700XX to turn regardless of the tire.
What Doug said.I would think the best thing to do if you want to stay stock width is get the Teixeira Tech upper replacement a-arm. That way you can adjust the castor and get the 700XX to turn regardless of the tire.
And worth every cent.go to his website and look at the video....he explains it pretty well
Im going to find out, Im getting the 23" razr2 fronts and the L8ton sway bar.Would the L8ton sway bar help with push in the sand?
Someone on here went with the 23s and apparently didn't like them as they were for sale shortly afterward and he put smaller tires on the front.OK But what is the castor going todo? and this is going to help in sand?
BTW Im getting razr2 23" fronts
