Ok, so i just got done changing over to Engine Ice, water flushed it out 2 time, put the ice in it, did what the manual said to do except i left the overflow empty (wanted to make sure i had enough for the entire system before filling overflow) i let it idle for about 5 minutes, at that time i throttled it a few times, seen some small bubbles comming out waited till all the bubbles stopped comming out, shut it down and filled the rad back up, and then filled the overflow tank, checked a hour or so later and it taken some from the overflow.
I let it run for about 10 to 15 mins after that, fan kicked on, but went off right away, did i do this right ? I just dont want to be over heating it because of a air pocket stuck in there.
