Flat side out.I’m trying to install the front sprocket and I’m unsure which way it’s supposed to go. Does it go in with the flat side out or does it go in with the grooved side out? Thanks.
Try some PB blaster, heat or a puller.Any pointers on how to remove the front hubs? I need to replace my discs and the hubs aren't budging. Thanks.
I have a slightly used auto tune if interested.Or at least, which base tune I should use from the dynojet website to get me by until I can get it professionally tuned?
I'd have to dig it out for pictures. I bought it used from someone else that said they never installed it. They plug into the PCv, and have to be hooked to power and ground. And like you said you have to have a bung welded into the header. $300 and hour for a tune isn't bad. They should be able to tune it within the hour, if they know what there doing with the PCv mapping.Can you give me more info on the auto tune? I might be interested after all
Haven't looked for it yet, been busy but I know I have it. And no you wont need a laptop to ride, lol. Only hook if you ride somewhere out of the ordinary and want to save that map for when you return. Or save your own area map, and remove the autotune, stuff like that.Any luck in finding it? And also, wouldn't I have to have a laptop connected to it at all times while riding for that?
