1 - 4 of 4 Posts
Guys,
I have just received my houser front a-arms, stage 4 elka's and am half way through the install.
My question is to others with similar setup as to what castor and camber they have used and or a consensus on what is a good set of numbers.
I mainly do dunes, tracks, a bit of jumping, but by no means mx...........
Cheers
Make sure you get an angle gauge very handy when doing camber and setting up the front end. Houser give you some handy paper work to set your front end up comes in the box concerning Camber, Castor and toe in. I run +2 in castor and about 2 degrees I think for camber. Man get the angle gauge.
1 - 4 of 4 Posts
