I typically just use a chain lube out of a can. But was recently told that the proper procedure is to clean the chain with WD40, then oil the chain with 90 weight oil, then spray it down with chain wax to hold the oil in.... Man, you are probably right this is one of those discussions that could go on and on, but I have been riding for over 30 years and have never done that process. Not saying it is bad, just never had enough time to do all that!:nuts: I think I'll keep spraying.....
