1 - 12 of 12 Posts
its a buger i use latex gloves to thread it in an thread it out i can grip the sparkplug better that way thats without taking tank off:confused:
This thread is confusing me....
Isn't it your typical deep well socket and short handled ratchet. I tighten it with my fingers till snug. Slide the socket in and give in another 1/2ish turn. Pop the cap on and done.
I change plugs constantly.
Its the position of the plug it is hard to get to.
Guess I am just used to it then from all the plug chops i've had to do :-/ Hardest thing in my opinion is just getting the yellow cap off.
Right on the plug wire/cap sometimes sticks pretty good. And I just used the plug tool that came with the quad.
I learnt the hard way and this way I found alot easier. I have big hands and can't reach the plug. I put the plug in the socket first then fit it hand tight, then tighten with a knuckle bar. It's easy when you get the knack of it.Put some lube on the cap, makes easy to get on and off.
i only use this technique when engine is cool.. baxters way when hot...:xx:
1 - 12 of 12 Posts
