i noticed an iratic ticking from my motor so i started investigating, i noticed that it was not a steady tap but kinda random in pattern, when i put a stethascope on the clutch cover it was the same eratic ticking patttern so i tore it down. fter i got the discs out i can take the basket and wiggle it side to side but the free flaoting flywheel (i assume it is) that goes inside of the discs does not wobble at all, what could cause one to be tight and the other one to be loose? looking at the parts diagram there is a washer between them and the one nut holds both of them tight.
let me know your input on it, i have to get the correct size socked for the nut today.
