Goto SummitRacing.com....Buy 15ft of the black 2in Exhaust wrap. Then Get you 2 radiator clamps, paint them Black with hi-temp grill paint or not.. Get the Exhaust wrap wet, it is easier to wrap you pipe when it is wet. Take your head pipe off your quad ( is easier to wrap ). Put your clamp on after you have made a wrap or 2 and tighten, then go ahead and wrap the whole pipe. Then put your last clamp on and tighten. Put is back on your quad and crank up, the water will burn off in a few min. Now you can cruise in 1st or 2nd gear and no heat shield and not burn your leg. Total cost 15-18 bucks. I have a Barkers full exhaust and it helped a lot. If you want some pics let me know. I even TIG welded up a shield and the wrap works better, or it does for me. I thougt this might help...
