1 - 6 of 6 Posts
I am looking between the two exhausts with either the dmc programmer or the ehs programmer. i want to know if any one can post dynos how do they sound and how does the power compare? any help will be great and thanks to all
look at the barker dyno thread, the # are up for barker. Plus Eric and Tim are on here every day and will help you in any way!
I run the HMF, and I heard at least 10 different brands yesterday (err two days ago now...) SCREAMING! and the Barker, well, Barks. It sounds mean and while yes Dave has other engine mods I am sure his exhaust helped his performance... I would go with the Barker... (ok, I advertised, where my free stuff? I dont get any? Aww man...)
thanks for the info how much of a difference did you notice after you got it on?
can't answer that honestly, i took a big gun off and EHS custom built a 11.5:1 piston, custom web cam, oversized valve springs, port work, proto type Barker exhaust(mine and nasty700xx were the first 2 barkers ever made for the XX proto type for what is now available) new air box lid, controller and tuned it on a dyno. so i went from mild to wild. Tim Barker did the flow work on his flow bench and this bike is sick, should be a video soon of the hole shot I launched on sunday, smoked the 450's big time!
both are great products i really like my dmc and have heard lots of good things about barkers i dynoed right around 46hp before my modified airbox and with a pcIII or v you should be able to get a little more
1 - 6 of 6 Posts
