I was hoping someone owned both. Would you please check the pivot shaft thickness (outer diameter) on the male part of the rear brake pedal on the 400ex with a mic or dial caliper. Wanting to know if a billet shifter and/or billet brake pedal off 400ex will work on the xx, this thing needs a diet. Could you also take the 400 shifter and try to fit it on the 700 and see if the spline count is the same. It would be very helpful and much appreciated. :tup:
