1 - 13 of 13 Posts
Our stock offset is 5:2 and you'd need to go with a 4:3 offset to be able to use 10" rims.
is this also the same with the rancher hubs
Even though I don't know about rancher hubs... I'd say that the hubs themselves are not the item you need to change offset for... It's in getting necessary clearance between the rim and the a-arm that's the issue.
i wont order wheels till i see the hubs on the quad...but i was thinking 4+3 offset at the rear..open to suggestions though...like the quad the way it is at the moment..about 2" overall wider than standard...the wheels i have at the moment on the standard hubs are 4+3 offset with 10" wheels...also 12" wide tyres
hubs have a 4 weeks back order..can anyone tell me if i would be safe enough to order the dwt wheels with a 4+3 offset for the rears
A DWT 10x8 :4+3 is only availible in a 4x144mm stud pattern If you want to run rancher hubs which is a 4x110mm stud pattern then the only rims availible are 10x8 in a 3:5 offset.
1 - 13 of 13 Posts
