hello guys i need your help. today i decided to to remove the reverse rev sensor glad i did. i rolled back the clear plastic cover over the top of the ecm loom and located the wires i needed to cut.
now this is the problem i removed the multi plug from the ecm unit and found the unit full of water. now i have never removed the plug before. but there is not any rubber seal around this plug. do you know if your ecm as a rubber seal to stop water getting in.
cheers gary
cheers gary
