1 - 18 of 18 Posts
I want more power on my 700xx but here aftermarket exhaust are illegal, wondering if I can just replace the stock header and air filter ?
If not then is there anything stealthy and that wouldn't be too loud that could give me a bit of hp more. Thanks.
IDK about replacing the header and using factory pipe? But have herd just adding a programer and a filter will help a little.
2 of the quietest, I have found is FMF and Leo Vince. The FMF is alot cheaper.
Thats all I am running and it does help out .
why are they illegal there? if you cant get exhaust youll have to do an cam an piston then if you want to spend more money get a port and polish job too :xx:
But would you want to build the engine, if you cant let the power out the exhaust?
Can I remove the decal of the barker exhaust ? Any other brand where it would be easy to remove decals and it would mostly look stock ?
its not an decal its aluminum and it is rivited to the cannister you can request barker not to put it there , all its going to do is fade and loose its color over time anyway from the heat the next one i buy is going to be minus that emblem because of that mine was red now its almost pink after 2 years of wear and tear and the anodized red muffler clamp is fading too :xx:
Ok, I'll check it out. How does the ehs stuff holds with time ? Does it requires frequent repack ?
Motoworks would be a nice exhaust you can peel the metal decal off and it pretty mellow if you leave the spark arrestor in it.
I have duncan racing fatboy 4 exhaust, K&N and vortex x10..
Zaust is far to loud, worse still it needs repacking around 6-12 hrs..
Cant be done with that so put stock pipe back on and its now pretty quiet..
Also get exactly the same flat out speed... Figure that one out !
get a sparks and p.c it black, looks stock just kinda noisey =p
where are you at that aftermarket exhaust is illegal? and is it a decibel limit or what? some after market exhaust are still not that loud. most companies will tell you roughly how many decibels their exhaust will be. If you want more power you pretty much have to go with bigger exhaust because honda choked the crap out of the 700 motor with too small exhaust to keep themselves out of lawsuits again as with the 250r.
Discussion Starter · #18 · (Edited)
Well I'm looking at the fmf powerbomb with stock exhaust. Would it work actually or should I just buy a filter and a programmer ?
I'm actually looking for the head pipe, a programmer and a filter.
1 - 18 of 18 Posts
