The Fram CH6015 oil filter will not fit in the TRX700XX, The side that faces the motor is not deep enought, It look's the same but it could cause alot of problems, because when you tight it up it will smash the oil filter, or cause you too strip your bolt. If any of you use a different type please tell the type and how they worked.
