Hi i just got a set of omf bead locks and got the 3:2 reading some posts have got me worried that this may be negatively affect the handling? Would i be better getting the 4:1 offset. These are still brand new and unridden. The front a arms and suspension are stock at the moment. No spacers are used either. Thanks
The stock fronts are 31/2 : 11/2 offset ,think it was Wayne Matlock who said. I cannot see a problem running 3:2 offset. I have 4:1 on mine and was going to get a set of 3:2 to go alittle wider.
I had a set of 2:3 on Lonestar +21/2 " a-arms on the 450r and loved them for MX. I kinda like stiff steering.
find someone with some offset wheels and bolt them up, i'm sure you know someone with a set of 4/144 offset wheels, they should fit virtually any newer sport atv...that way you can use your own judgement and not ours because apparently some like it and some dont...
I have DWT front wheels with 3+2 offset and love them! I got the razr 2's at the same time and don't know if it's mainly the tires that made it better but a lot of the push is gone. The 3+2 offset makes it 47.4 inches wide up front and I ride really tight trails and never had a problem being too wide.
Widening the front with an offset or wheel spacers is said to give more feedback through the bars but its only .75" wider per side and I couldn't feel any more feedback. I do have a CCP stabilizer which I think is the best mod on any quad.
You should be fine with either offset, there is not a huge difference in handling. Yes, you may have a little bit more feedback with the 3:2 wheels, but it will not be that noticable. The problems with offsets are when you go to a 2:4 or even a flipped stock wheel, 1.5:4, then you can really feel the increased feedback. Stock wheels are 4:1.5 offset, so with 4:1 offset you will be about a inch narrower then stock, while 3:2 you will be a inch wider. If you are running stock arms and are looking for a little more width, go with the 3:2 offsets, they should work fine.
I talked to the Honda dealer and they said the 4+1 offset is the wider stance. I am about to order a pair and I am now going to check further to make sure I get the ones I want.
If you have a 4:1 offset, it is 4" inside, 1" outside. 3:2 offset is 3" inside, 2" outside, etc. This is pretty much the industry standard to measure rim offsets.
This thread is great. I finally understand off set. You all are the best.
Related Threads
Honda TRX700XX Forum - Club700XX
134.3K posts
31.7K members
Since 2007
A forum community dedicated to Honda Club 700xx owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
