I put my EHS controller in the airbox. I took the EHS block off billet block an... I drilled a hole on the very edge an notched it, put the controller through the stock air intake hole an... slid the billet in with the wires in the groove I drilled an cut, then I took a small ice screw container I had (much like the q-tip case) an.. I drilled a small hole for the wires to come out of it an.. I attached the case to the airbox with some velcro brand hook an loop, an then attached the controller inside the little case with some more velcro brand hook an loop. Then I siliconed the groove where the wires pass through the groove I cut in the billet block off. I can now take off the seat and airbox lid, open the hinged cover of my q-tip type plastic case an adjust as needed, with the protection of the airbox, and the plastic case. I check it every once in a while to see if it had come loose, but... after 50 miles of some pretty wooped out trails it was still hook an looped in place.
