I finally got my bike where it can turn over after a complete teardown from an engine explosion. I took the fuel pump assembly off and cleaned as much as I could and replaced filter with new. The outside of the fuel pump was rough so I cleaned all of the rust off and put it all back together. When I took it apart, I had bad gas in it, which lead me to do all of this. Now when I go to start it, It turns over and won't start. I pulled the plug and it sparks healthy but no fuel smell so obviously no fuel. I plan to check the fuel at and before the injector tomorrow. If need be, where is the best place to buy the injector and is it possible to just by the fuel pump without buying the whole assembly? Thanks ahead of time.
