How Does The Stock Xx Handle A Track?
Exactly. Tighten your front preload at least halfway or you'll end up over the handle bars. A 13 tooth sprocket for $20 would also help a lot powering out of turns.goodish adjust ur front shocks so u dont bottom out and make the take of like a bat outa hell when u get outa turns
so I just have to turn the preload to the right a little bit right?Exactly. Tighten your front preload at least halfway or you'll end up over the handle bars. A 13 tooth sprocket for $20 would also help a lot powering out of turns.
