1 - 11 of 11 Posts
what size would you guys reccomend front and back? :thanks:
They don't make Razr 2's for the back of ours.
But the sizes you need are in my sig.
You can order a set of 10" wheels for the back and Razr 2s will work just great, I have them all the way around and its fantastic.
Yes but 10" wheels cause you to lose your mud scrapers and widen the rear end correct?
Doesn't widening the rear end make it handle worse?
And in places I ride having a wider rear end will get you hung up and wont let you go through.
It does widen it approx 2" I dont notice it personally.. as well as the mud scrapers being gone... If thats what you are riding then yeah stick with the stocks.. but thats kinda the only options for Razr 2 in the back.. I do belive that Razr 1 works though... not 100% since I didnt look up sizes. Handling wise I also didnt notice to much of a change.
Ah. I have regular RAZR's all around on mine. If I widened my ATV 2" I'd have to pull a trailer behind my F150 because it wouldn't fit in the bed.
Ahh that sucks Didnt realize the 150 was that much more narrow then the 250... my quad fits in my 250 with enough room for my ramp to lay flat
The pinch point in the bed would be at the fenders, right? So your back tires wouldn't be that far in anyway. Unless you've got a stepside or something.
You're right. I have a 1993 stepside.
I rub the sides if the truck isn't on level ground or if I'm off just a little bit.
Wow, that is snug. Just put you a ramp up to the top of one of the bedrails and park it all angled, you'll be fine. :)
If you want to stay with stock rims, which I decided to do... At least until I bash the crap outta them.... You can use Razr2 on the front in your choice of 21", 22" or 23" (M933)
And for the rear, you can use the 6 ply Razr (M932) 22x10x11
1 - 11 of 11 Posts
