1 - 12 of 12 Posts
I rode my xx for the first time this weekend an... the only thing I didn't like was the stock bar height. I would like it atleast an 1" higher, if not 2". I have the precision anti-vibe risers an they will only raise the bars by about 1/4" above stock, so... I'm looking for suggestions to be able to incorporate the anti-vibes but find an aftermarket bar that's higher than stock.
I have the pro taper high bend bars.
Pro taper atv high bend will raise them some. Not the 2" but I like it. You will have to consider longer brake lines I think going that high as I only did the high bend bars and had to release the hose from one restraint and that's all the length I think I can get from it
The atv highbend bars you guys have, is it the pro taper SE ATV high? I have the PRP anti-vibe risers which PRP says will raise the bars roughly 1/4-1/2 inch, so if I went with the highbend bars I might be ok on cable length an be right close to where I wanna be. Is the cross bar on those bars removable? I ask that cuz you have to slide the PRP anti-vibe risers onto the bars, they don't come apart. They are a pain in that reguard but I do notice a difference in fatigue without them.
Yeah pretty sure they are the SE. The cross bar is removable.
last question. The pro-taper SE high bend is 7/8" all the way right? As that is the size anti-vibes I have.
Alright, I answered my own question, after reading a little I guess the "SE" stands for "Seven-Eights" haha. DUH! I love this forum I'm gonna order em up an if I need more height I can always add a riser block below the PRP risers. Thanks for the replies guys!
Well i let my buddy ride my xx. he rolled ir over and bent the steering stem. So i replaced it with a houser steering stem. +1". Feels just right now.
what's the equivalent bend for our stock handlebar, raptor bend???
and how much highter is the SE highbend than stock?
I measured the stock bars at about 5.5 inches give or take, an that was with a tape measure. The SE bars come in MANY different heights, I went with the ATVHIGH bend bar an... according to the chart at rocky mountain that I posted a link to a few posts back (hint hint) they are about 6.5 inches, so... I'm guessing roughly an inch to inch an a half higher than stock.
1 - 12 of 12 Posts
